94 honda civic doors leaking
Old Jul 14, 2007 | 09:24 PM
jrh187's Avatar
Default 94 honda civic doors leaking
Both of the doors are leaking, at the bottom of the window, into the doors. Replaced the molding at bottom of window, top of door. Is still leaking. Has anybody else had this problem, and if so what would cause it?
Old Jul 15, 2007 | 06:48 AM
Default RE: 94 honda civic doors leaking
Aloha and welcome to the forum, Have your doors ever been in an accident? pushed in, or warped. I have a 02 civic, when I wash the car and pour or shoot a stream of water at the base of the window, I do get water coming out the bottm of the door, with a lot of dirt, but the seal is still good.
Old Jul 15, 2007 | 12:04 PM
jrh187's Avatar
I had got a carfax report and it had been in 1 minor accident, but it was just to the front on driver's side. I don't think anything would happen to the passenger door. The body man I had look at it said that both doors look fine. The only thing that he could figure was that I had to have the door skins on inside to put more pressure on the window pushing out.
Old Aug 18, 2007 | 11:59 PM
Fretplayer20's Avatar
You said you replaced the molding at the window base, I would go back and make double sure that it is stretched the ENTIRE lenth of the window. My brother was having a similar problem a while back and it turned out that his door was slightly tilted forward and the water was running to that end and slipping into a small uncovered portion of the seem. Just a thought. I know it's an obvious solution, but sometimes it's the obvious stuff that gets discarded the quickest. Good Luck.
Old Nov 23, 2007 | 11:48 PM
vtec 1.6's Avatar
Dude u migth wonna think about getting a new door ya retard
Jschoend
Apr 25, 2019 01:50 PM
LLCPolling
Aug 23, 2014 07:48 PM
jstagn
Feb 13, 2013 04:37 PM
evoxbeck
Jan 11, 2013 11:57 AM
bsterr
Feb 28, 2010 02:37 PM
