Air Condition not blowing cold.
Old Jul 31, 2018 | 09:59 PM
marsala4's Avatar
Default Air Condition not blowing cold.
99 LX 1.6
Here's the deal, The compressor is running like it should, comes on and turns off when I press the A/C button, fan comes on like it should, but, air is not cold.
The high side pipe gets real hot bu the low side does not get cold. I hooked up the gauges and checked the pressures, the high side was low. and the low side was a little low as well.
Could I have a blockage somewhere. I thought if the compressor was not running it would be low on freon, but the compressor runs like it should. the fans run like they should. I added a few ounces but got no change.
Thanks in advance.
Old Aug 1, 2018 | 02:44 AM
welcome to the forum with all the above working the following items could cause the a/c to blow not cold. a/c condenser coil need cleaning, possible restriction in the line/clogged orifice tube, faulty expansion valve, blocked condenser.
bonegrafix
May 21, 2014 02:59 PM
William_agus
Jan 26, 2014 09:40 AM
QUESTSEEK
Jul 11, 2011 05:12 PM
shad9876
Sep 3, 2008 12:57 PM
cleartouch33
Dec 28, 2006 02:15 AM
