civic idle problems
Old 12-11-2008, 03:20 PM
billyc's Avatar
Default civic idle problems
Just Recently, My Radiator Cap Broke Off Inside Of My Radiator, Letting Water Out. I Didnt Notice It Running Hot Until I Smelled It, I Immediately Pulled Over And Got A New Cap, And Ever Since Then Ive Been Having Problems. It Would Get Hot Very Fast After Warming Up, And It Would Blow A White Smoke Out Of The Exhaust That Smelled Like Burning Oil, So I Thought It Was The Head. Also, It Would Turn Off When It was Idling After Warming Up. I Just Replaced The Radiator And The Head In It. It Fixed The Problem With It Running Hot, But It Is Still Shutting Down When Its In Idle After Warming Up For A Few Minutes. Any Solutions? Thanks.
Old 12-12-2008, 11:24 AM
Default RE: civic idle problems
welcome to the forum, have you bled your coolent system of airbubbles, check the egr valve for debri or sticking, check all vaccum lines for possible leaks ( you can use starting fluid, and if there is a line leak, the idle ill increase.) check your idle control valve.
Old 12-12-2008, 02:56 PM
billyc's Avatar
Thank you, also what would cause an oil light to come on? i changed the oil and put on a new oil filter, could it be low oil pressure? if so, how would we improve it? thanks
Old 12-12-2008, 04:01 PM
possible clogged oil filter, scavange pump ( oil pump) oil screen clogged with carbon, this would be from an engine that did not have regular oil changes, also the heated engine could cause lots of carbon debri dropping into the oil pan. check your oil filter if it has a lot of carbon or debri. Bit hard to see.
bcole6
04-30-2013 09:30 AM
Squashua
08-10-2010 02:28 AM
oojuanky
03-10-2010 03:28 PM
pumer
11-17-2009 01:29 AM
1982buick
10-22-2009 10:25 AM
Quick Reply: civic idle problems
