Civic Si, 1990; identity of parts on the engine.
Hi,
This photo illustrates the rear side of the engine in a Civic Si,
1990. The intake manifold has been removed and the red gasket remains
on the head. The connection for the oil filter is in the lower left.
http://easthope.ca/CivicSi1990EngineRear.jpg
Will someone please explain two parts which I haven't yet found in the
Haynes manual.
(1) The steel tube, about 2 cm diameter, running across the block
above the oil filter connection.
(2) The object on the right side of the oil filter connection.
Approximately square shaped with round corners and a rubber surface.
Thanks, ... Peter E.
Haynes manual.
components - exploded view" the steel tube is part "7 Water pump inlet pipe".
Regards, ... Peter E.
ASar
Jul 14, 2009 04:27 PM
cosmo
Jul 31, 2006 11:15 PM
cosmo
Jul 25, 2006 12:25 AM
greengoat07
Apr 30, 2006 04:09 PM
