Civic Si, 1990; identity of parts on the engine.
Old Aug 17, 2017 | 10:51 AM
peasthope's Avatar
Default Civic Si, 1990; identity of parts on the engine.
Hi,
This photo illustrates the rear side of the engine in a Civic Si,
1990. The intake manifold has been removed and the red gasket remains
on the head. The connection for the oil filter is in the lower left.
http://easthope.ca/CivicSi1990EngineRear.jpg
Will someone please explain two parts which I haven't yet found in the
Haynes manual.
(1) The steel tube, about 2 cm diameter, running across the block
above the oil filter connection.
(2) The object on the right side of the oil filter connection.
Approximately square shaped with round corners and a rubber surface.
Thanks, ... Peter E.
Old Oct 9, 2017 | 04:47 PM
peasthope's Avatar
In Haynes manual 42023, _Honda Civic '84 thru '91_, page 3-4, illustration "3.10 Thermostat and associated
components - exploded view" the steel tube is part "7 Water pump inlet pipe".
That part still baffles me. A cover of a breather or vent? In the photo referenced in my original post, it is below the inlet tube and right of the oil filter connection.
Regards, ... Peter E.
ASar
Jul 14, 2009 04:27 PM
cosmo
Jul 31, 2006 11:15 PM
cosmo
Jul 25, 2006 12:25 AM
greengoat07
Apr 30, 2006 04:09 PM
