compression
Old Dec 2, 2007 | 06:02 PM
mickeyp's Avatar
Default compression
neeed help people any ideas on compression ........... high comp low boost or high boost low comp
Old Dec 5, 2007 | 03:45 AM
Default RE: compression
Welcome to the forum mickeyp, enjoy your stay,hope we might be able to help. Boost, on a diesel engine, boost with high compression, on a gas engine, generally high boost, low compression. What are you trying to boost? If you have high boost on a high compression gas engine, your fuel octane will need to be a lot better than pump gas. Such as a formula 1 engine, boost is up to 35-45 psi, and the engine produces up to 800 hp.(engines are short in life ) running on methanol fuel
this_25
Aug 10, 2009 07:46 AM
jonesdesign
May 27, 2009 10:24 PM
kan
Nov 6, 2008 07:16 AM
infrantry
Mar 30, 2008 05:22 PM
rob11059
Oct 5, 2006 01:57 AM
