D-series question.
Old Jan 18, 2007 | 04:20 PM
honda_guy7785's Avatar
Default D-series question.
Will a 2000 Civic D-series 1.7L block accept a 1995 D-series 1.6L Vtec Head? the plan is to make the whole motor O.B.D. 1 AFTER CONVERSION.
Old Jan 28, 2007 | 02:26 AM
josh2113's Avatar
Member
Default RE: D-series question.
Ok first off there is no 1.7 in a 2000 civic. I believe that started with first of the generation 7's. the 2000 model year was the last of the gen 6's. You should have a 1.6 of some shape or form assuming you have a DX or LX trim line the vtec head 95 will indeed bolt on. As far as converting your car to OBD 1. Why? That would be such a pain the *** it wouldn't even be worth it for a daily driver. I believe you would also have to switch the distributors. Don't forget a vtec controller. And do a little research there on hundreds on sites that explain in detail convert non-vtec to vtec.
Nic Graham
Aug 11, 2014 03:19 AM
rpsperformance
Oct 6, 2009 12:39 PM
kwlakes
Sep 17, 2009 09:30 AM
kayslay
Mar 29, 2009 12:26 AM
silverbullet
Jun 21, 2007 12:31 AM
