gas smell but no leak
Old Dec 4, 2023 | 02:29 AM
awesomecivic's Avatar
Default gas smell but no leak
Hi everyone.....I have a 2003 Honda Civic EX coupe...great car...lately I've been smelling gas but have looked underneath and find nothing leaking either in the front or the back of the car...the smell is coming from the left rear of the car...close to the fuel filler lid...but not even quite there... Could it be a bad gas cap?? The check engine light is NOT on...but I read that if the cap is bad and it's emitting fumes, it won't always turn the check engine light on...so I'm hoping and thinking this might be it??
Old Dec 4, 2023 | 12:41 PM
If necessary take the heat shield off the exhaust manifold. See if the manifold is cracked.
Old Dec 4, 2023 | 03:55 PM
welcome tot he forum. It is possible that the gas cap seal is worn after 20 years of use. Gas cap is not to expensive and easy to replace.
Old Dec 4, 2023 | 08:13 PM
thanks for the post and the advice...that's what I'm thinking...gas cap.....I took the car to my mechanic today and he looked under it, as did I earlier, and saw no evidence of leaking and of course, it behaved there and no gas smell...but I can easily replace the gas cap because as you said, after 20 years it could be a bit worn...
thanks again..I did find an OEM on ebay for 15.00..not a substitute..or LKQ..but an actual OEM...so yeah..I'll double check to make sure it is OEM and get it..
Old Dec 5, 2023 | 10:24 PM
You are wasting your money. If the cap were allowing that kind of vapor to leak you would have had a cel for it long ago.
Old Dec 6, 2023 | 01:30 AM
haven't wasted any money...haven't purchased a new cap....I'm not sure what a "cel" is
Old Dec 6, 2023 | 08:23 PM
Check engine light
Nguyener
Mar 26, 2011 09:03 PM
James
May 24, 2009 10:59 PM
rdkeisman
Dec 8, 2008 02:27 PM
jpmack
Apr 22, 2008 08:16 PM
