Need Civic Help?
Old Oct 7, 2011 | 09:02 AM
  #31
pcompton75's Avatar
How hard is it to put a s2000 motor in a civic i have an ek hatch n was just wonderin
Old Oct 11, 2011 | 10:06 PM
  #32
lowlife9's Avatar
very hard considering the s2000 is rear wheel drive your going to want a k20 engine from a RSX.
Old Dec 14, 2011 | 06:32 AM
  #33
rednwhiterocket's Avatar
I don think a b head would even set on a d block go with b series
Old Mar 3, 2012 | 04:12 PM
  #34
Brianw's Avatar
Hello my name is Brian and my fiancé and I have a 1997 Honda civic lx with an automatic transmission and it started to act up slams hard into 2nd gear when up shifting then when down shifting coming to a stop it slams into gear to someone please help me I really don't wanna have to put a new transmission in it unless it is the tranny checked the fluid it's full and still has the red color and it does not smell burnt at all so kinda confusing me a little bit so someone please help me
Old Mar 4, 2012 | 06:53 AM
  #35
brk2586's Avatar
OK so it should still be an M4LA ...not 100% sure but the principle is always the same. import transmissions ...especially hondas, do not rely on fluid pressure to shift through the gears, it is all spring and clutch activated internally,literally just bathing in the oil inside the case, a good design, but unfortunately, as you'll come to know....almost every automatic civic from our circa hits 2nd a little hard and dumps into drive a bit rough after about 100000 miles or so. What can you do? the bands inside need to be adjusted. . . which is buku bucks to spend on your little civic. whole trans has to come out for adjustment. it is the real solution, yes.....but not a practical one. if your going to take it out, might as well find another to put in. Lucas heavy duty transmission fix. 1/4 of the bottle MAX and not a drop more. dont wanna make it too thick, Will smooth out your bang to an exceptable shift. . . and go easy on it till it warms up. cold oil doesnt like to find crevasses, cracks, seals, corners, etc. Ive been running my 91 with this mixture of trans fix / fluid and still shifts crisp to this day with 190XXX on the clock. Banged like hell when I first got it. . . a common problem
Old May 17, 2012 | 07:50 PM
  #36
s76withh22's Avatar
Default Bride race seats and takata hardness
If any one would like to make an offer on my Bride low rise racing seats ..
please Email me at tonycell22@gmail.com
My little brother crash the great little civic .. before I could install them
thanks
anthony
Old Oct 13, 2012 | 06:30 PM
  #37
zoomersgarage's Avatar
Well you might need to trim it down some more or it's rubing in a different area, this could be due to the engine having a retro-fitted timing gear on it, but I wouldn't go to the extent of swaping out an engine becuase of the small noise, just turn up the radio abit, the enginge is perfect.
Old Oct 13, 2012 | 06:32 PM
  #38
Wow Tony, at first reading your post, I though you were taking offers of your Bride, I was going to say, I know how you feel; i'm about to put mine up for sale here soon.
Old Oct 13, 2012 | 06:35 PM
  #39
Hey Brian, good new is that you don't need a tranny, if the level and color is good then what you need are new shift selonoids that are accessible when you take off the tranny pan.
Old Oct 13, 2012 | 06:43 PM
  #40
Hey Mitchell, sound like you need to replace the rotors on both sides #1 pulsating issue there with my experience, especially if you drive up/down hill alot, second, when your in there back off alittle of the tightness on those wheel bearing nuts; might be too tight; it's just supposed to be lightly snuged.
