Need Civic Help?
Old Apr 1, 2013 | 09:10 PM
  #41
91CivicSI's Avatar
i have a 91 honda civic ed7 swapped b16a but i cant seem to find a starter that will fit my engine i have a mitsuba and no one has it any ideas
Old May 27, 2013 | 05:30 PM
  #42
kbrook1218's Avatar
Default 96 civic oil leak
Hi I'm Kelsey and I have a 96 civic ex with an oil leak that appears to be coming out of the left side of the engine block where I believe the timing belt is. Do you have any idea on what it might be and if so what it would take to fix it?
Old Jun 9, 2013 | 04:08 PM
  #43
Guinac's Avatar
Default Manual window problem
Hi.. I have a '96 honda civic cx hatchback and my window doesn't seem to roll all the way up, it will go up as far as my crank will allow and it's cracked open towards the front of my window. It's closed in the middle of my window and then in the back of the window it's kind of off and leave a small gap between my door and the window. I'm not sure if there's a way I could fix it or if I'd have to take it in.
Old Aug 4, 2013 | 04:57 PM
  #44
4ndr3w's Avatar
Default Should I buy?
http://www.crxsi.com/for-sale/cars/1...1375034677.htm
3400 dollars. All electric works. He's driving himself 2 hours to meet me in Cincinnati, along with me driving 5 hours. Motor was professionally rebuild at 175k. 206k miles now. Clutch was replaced when motor was rebuilt. Interior is good. No sun spots on paint. No leaks. Doesn't smoke.
Would it be worth assuring him i'd buy it if he'd hold it until the next weekend? He said he has a guy coming in 2 days to come look at it, so I could offer more than the other guy. Or, should I just pass it up? My problem is that I can't get there until next weekend.
Thanks.
Old Aug 5, 2013 | 10:18 PM
  #45
hadden's Avatar
Default white/blue smoke
I just bought a 1989 civic hatch and knew it wasn't perfect but didn't know what the problems were. it blows white/ blue smoke when revving too high, if I shift early it wont smoke and it isn't over heating. it has a new head and gaskets, also new ignition control module and ignition coil. isn't leaking oil just burning it. thinking about replacing the valve stem seals then the oil cooler oring and seeing if that stops the smoking. any ideas or suggestions would be great!
Old Aug 29, 2013 | 01:42 AM
  #46
Greg Ackerman's Avatar
are tail lights interchangeable between the 90s model civic 3 door and 4 door
Old Dec 3, 2013 | 08:24 PM
  #47
adrianbayer95's Avatar
I have a 2000 honda civic ex and I need to replace the entire exhaust system from the engine back. I wouldn't mind upgrading to a performance exhaust but the problem is I don't have a large budget and I want something that doesn't create noise. What would you recommend I get and where?
Old Dec 3, 2013 | 08:50 PM
  #48
corair bowman's Avatar
I have a 89 Civic that i bougth with a B18A1 in it and it has a check engine light on I tryed the jumper point and it does not flash any engine codes... Help!!!
Old Jul 18, 2014 | 08:27 AM
  #49
edwinrmr94's Avatar
Default 1989 shocks
I need help, tryin to find out what year civic shock will fit a 1989 civic ef sedan... I want to put coilovers... I have some shocks but dont know if they fit on my car... if anybody can help please and thank you will really appreciate it
Old Jul 18, 2014 | 08:34 AM
  #50
edwinrmr94's Avatar
I would probably check the crankshaft seals, it is a hassle to fix. You would need to take the timing belt cover off to get to it
