Need Civic Help?
Old Jul 18, 2014 | 08:37 AM
  #51
edwinrmr94's Avatar
Originally Posted by kbrook1218
Hi I'm Kelsey and I have a 96 civic ex with an oil leak that appears to be coming out of the left side of the engine block where I believe the timing belt is. Do you have any idea on what it might be and if so what it would take to fix it?
I would probably check the crankshaft seals, its a hassle to fix. You would need to take the timing belt cover off to get to it
Old Oct 31, 2014 | 10:35 AM
  #52
Brandon Mesa's Avatar
i have a 2003 civic
everytime i attempt to turn the car on, it makes a ticking noise and whining sort of noise, yesterday i replaced the starter with a refurbished one i bought a couple of months ago how ever the car still has the same problem.
also everytime i turn on my headlights and proceed to turn on my radio,slide the windows down, turn on ac, the headlights slightly dimmer down, could this be an alternator problem?
i also bought a battery and cleaned the connection cables about a month ago so i dont think thats the problem.
please help!
fyi the car takes a couple of tries to turn on, yesterday after school i spent 15 minutes trying to get it to turn on
Old Nov 1, 2014 | 01:04 PM
  #53
kbrook1218's Avatar
Default Reply
I took it to the shop that I always go to and told them that it was the crank shaft seal (about 400 dollars shop costs for a four dollar seal). They told me it was my actual oil pan so they welded that and it still leaks. I agree that it is most likely the crankshaft seal which is underneath the timing belt. Good luck.
Old Jun 6, 2020 | 03:08 AM
  #54
azn3692's Avatar
Default Decisions
Hi, I'm going to buy my first civic and I'm having a hard time deciding on what to get. I've looked at 2 different ones and can't pick. One is a very clean ek hatch with a boosted b20b non vtec and the other is an eg hatch with a jdm b18c type r motor. Here are the links to the cars: https://offerup.com/item/detail/798159833/
https://offerup.com/item/detail/635654539/
Old Jan 30, 2021 | 01:10 PM
  #55
Dmac1976's Avatar
Default Civic motor swap
Need a little help. I have a 2003 civic coupe with a 1.7. Trying to put a 2.2 VTEC out of a prelude. Anybody got any suggestions?
Old Jan 30, 2021 | 01:15 PM
  #56
Dmac1976's Avatar
Need a little help. I have a 2003 civic coupe with a 1.7. Trying to put a 2.2 VTEC out of a prelude. Anybody got any suggestions? Sorry for the extra post I’m new to this not sure how it all works appreciate the patience
Old Jan 30, 2021 | 09:26 PM
  #57
welcome to the forum you will need to adapt the front engine compartment from the prelude into the civic chassis, and piggy back the ecu from the prelude into the civic ecu. or modify the civic front chassis to accept the 2.2l engine. lots of money, time and can you weld.
QuiGonJohn
Mar 22, 2020 09:08 AM
Vicki Harris Graham
May 6, 2019 08:22 PM
Just Chuck
Jul 9, 2016 09:31 PM
WagoSlammin89
Feb 27, 2014 04:22 PM
Carl02
Jul 24, 2008 10:20 AM
