Oil leak on a 93 civic!??
Old Sep 1, 2009 | 05:05 PM
elc0lomb1anito's Avatar
Default Oil leak on a 93 civic!??
So theres an oil leak on my Civic and I think its coming from the gasket between the transmission and the engine... Dont know much about gaskets but will appreciate a little help with this. I do know its oil and not transmission fluid because its black... and my oil level is always going down.
People have told me it might be the oil pan but if you own a 93 civic you know the oil pan its on the driver side and the leak its coming from the middle between the engine and the transmission.
If you know how to change this gasket I would appreciate you telling me how.
Thank you!!!
Old Sep 1, 2009 | 09:59 PM
91haydenSI's Avatar
welcome to the forums.. it might be the side of the oil pan gasket. not hard to change.. if it is a gasket between the engine and tranny you will have to pull to motor to pull the tranny to replace the gasket
Old Sep 2, 2009 | 05:38 AM
welcome to the forum. As 91haydenSI explains, the oil pan gasket, go to hondaautomotiveparts.com and enter your car info, it will show the block, oil pan gasket on the trans side.
Old Mar 22, 2010 | 08:34 AM
Donkeydawn11's Avatar
My 1994 accord is leaking in the same area I suspect it to be coming from above on the passenger side above the oil filter there is a black hose I dont know what its called .
Old Apr 3, 2010 | 11:40 AM
jo0424's Avatar
it can also b the rear main seal! have to pull motor to fix that problem cheap seal tho.
PHC
Jul 15, 2013 02:29 PM
kbrook1218
May 27, 2013 05:21 PM
mowntnbkr
May 31, 2007 07:14 AM
Daniel33
Apr 12, 2007 02:39 PM
XHONDAX
Sep 17, 2006 09:31 PM
