p0170 code need help
Old Oct 5, 2023 | 06:18 AM
nvto's Avatar
Exclamation p0170 code need help
Helloo, alright so I put my OBD scanner on my 97 Civic Ex which is auto, and sometimes when I am driving it's hard at times to accelerate (like driving on the freeway it's really smooth, but the moment I'm on regular streets it fails to give the proper acceleration if that makes sense, hard idles and all). The code ended up being P0170 (fuel trim malfunction bank 1), tried finding videos on YouTube but it doesn't really show the problem for my vehicle so I wanted to take it to the forums. Any suggestions on what to do or what it could be? I appreciate any feedback!
(PS: Before the p0170 code came up, another code showed days before which was p0505 "idle control system". not sure if they're both the "same" in a way or just two different problems when I cleared it, then the fuel trim code popped up afterwards).
Old Oct 5, 2023 | 01:24 PM
What are your trims doing?
Old Oct 5, 2023 | 05:23 PM
nvto's Avatar
I wish I had the answer, but I'm not sure 🤣
Old Oct 5, 2023 | 07:56 PM
You don't have a scan tool?
Old Oct 5, 2023 | 11:19 PM
nvto's Avatar
If this is what you are referring to , the only thing that popped up
Old Oct 6, 2023 | 09:46 PM
That's a code reader. They are not worth much. Need live data.
Old Oct 8, 2023 | 04:20 PM
nvto's Avatar
Alright, appreciate it!
Old Oct 13, 2023 | 06:57 PM
nvto's Avatar
@grcauto Okay so I bought the scan tool, and I see what you were talking about. It shows EVERYTHING. So basically the fuel trim is good (for now), but I see another problem regarding the idle. So I ran a "throttle relearn" test and it basically said something about connecting an "SCS shorting connector to the SCS connector". I didn't know what the connectors meant so I canceled the test, tried looking on the net and it's saying it's under the dash but I have no clue what wire it is. Any ideas??
Old Oct 13, 2023 | 10:22 PM
There's a connector that you have to jump with a wire. It throws it into service mode.
Misfit
Aug 14, 2023 12:06 PM
Salhonda
May 2, 2015 12:16 PM
Harman
Aug 21, 2012 07:52 PM
C Check
Oct 9, 2009 09:49 AM
honda abdullahi
Jan 17, 2008 09:39 PM
