P1362
Old Dec 12, 2020 | 07:13 AM
StManson's Avatar
Default P1362
Hey. I got a code for the P1362 for my 2002 Honda Civic LX but I had already changed the sensor. Car started fine, warmed up, drove around the corner and it just died on me. I checked my battery connections, no dim lights, starter spins, just wont start. Could anything else be causing this code?
Old Dec 12, 2020 | 10:36 PM
welcome to the forum if you are using an aftermarket sensor, it may be the cause of the failure.
Old Dec 13, 2020 | 10:16 PM
StManson's Avatar
Default Figured it out (:
Hi! Thanks for the reply. I took it to my dad and by ear he said it was the timing belt. Took it apart and sure enough he was right!
Issue: P1362 code
Caused by broken timing belt, sensor couldn't find TDC
Old Dec 14, 2020 | 08:24 PM
good find, thank you for the feed back. hope you get that 02 up and running. i had one 5 sp. 235k miles +
Old Dec 14, 2020 | 11:07 PM
StManson's Avatar
Default Thank you!
Thank you! It currently has 250,000 miles on it. My uncle has a Scion XB with 600,000 miles on it so I believe I’m in good hands with his and my dad’s advice (:
Deadpool
Mar 13, 2018 10:18 PM
Harman
Aug 21, 2012 07:52 PM
samuel_gatech
Nov 4, 2009 04:46 AM
C Check
Oct 9, 2009 09:49 AM
chuck norris hx
Nov 30, 2006 10:24 AM
