TURBO HELP !!!
Old Aug 2, 2007 | 02:00 PM
civicboi97's Avatar
Default TURBO HELP !!!
hey me and my friend are installing a t3/t4 turbo on his 1995 honda civic d15b7 and i was wondering if anyone could help me out bytelling me a way to get instructions forinstalling theturbo kitor by telling me instructions on how to install the turbo kit ??!! Thankyou
Old Aug 2, 2007 | 04:41 PM
kayslay's Avatar
Default RE: TURBO HELP !!!
after you install turbo manifold and turbo witch shouldnt have been that hard. Route either of the coolant lines from the turbo to the thermostat housing. Cut to fit. Connect the coolant line to the fitting on the side of the thermostat housing that originally connected a coolant line to the throttle body. Route the other coolant line from the turbo to the throttle body coolant fitting. Cut to fit. Connect the line to the throttle body coolant fitting. Tap your oil pan with a line that will be your oil return line from your turbo. and then run your "Y" spliter on the back of your head where you have a outlet oil hose. then run that line into your tubo inlet. and if you guys cant figure out how the hoses go. you shouldnt be doing this at all. sorry this is instructions for for people who have mechanical knowledge. if you dont know what i am talking about then please dont try this at home.
GoReGaSm
Oct 30, 2009 12:20 AM
powernut
Apr 11, 2009 07:33 AM
evidentloss
Oct 8, 2008 05:02 AM
98exd16a7
Apr 8, 2008 01:39 AM
helcat17
Aug 3, 2007 05:02 AM
