Honda Detailing Talk about any Honda detailing questions here.
What foam would go between a spoiler and the trunk lid?
Old Sep 29, 2018 | 06:54 PM
Honda_Addiction's Avatar
Member
Default What foam would go between a spoiler and the trunk lid?
The spoiler I have decided to put onto my car came with foam attached to it. It's pretty dried out so I'll have to remove that and replace it. What foam should I use?
Thanks!
Old Sep 30, 2018 | 01:00 AM
i have used the following to install spoilers. weather strip with stick on one side, with stick on both sides, scotch double sticky side tape, rtv sealant clear, polyurethane tape. all work good. make sure the surface is clean. isopropal alcohol
Old Sep 30, 2018 | 01:08 AM
Member
Weather strip, sticky on one side? Where would I buy that? It needs to be about a 6 inch x 6 inch piece that I can trim down.
Rubbing alcohol? Thanks.
Old Sep 30, 2018 | 01:22 AM
home depot, lowes, auto parts, auto paint supplies, rubbing alcohol to clean surface before adhesive to stick. sticky on one side was used when experimenting on several different spoiler to test on cars. easy to remove off the car deck lid vs. leaving on for ever, use double stick surface.
Old Sep 30, 2018 | 12:37 PM
Member
Thanks, I'll check next time I'm out.
I believe though, the 1998 to 2002 Accord trunk lids (and perhaps years after) have places punched into the trunk lid underside indicating where the factor spoiler mounts. Anyone know for sure?
Old Oct 2, 2018 | 08:06 PM
Member
Old Oct 3, 2018 | 08:20 AM
Member
Uh oh! Read the "question and answer" section!
What about this instead?
Amazon Amazon
Shaun Smith
Oct 16, 2015 05:24 PM
buzzking
Mar 29, 2014 01:56 AM
G-Man
Jun 17, 2013 09:28 AM
devastator187
Sep 26, 2008 10:47 AM
BradJFelix
Apr 25, 2006 05:26 PM
