94 accord ex with abs brake issues
Ok ..so first off, It started with a abs light and a soft pedal and high idle.
Key points
abs light
soft pedal
high idle
So started cheap... master cylinder "brake", then discovered the booster was loosing vacuum. SO I replace it .... a bit of a pain but I got it done.
I then proceeded to bleed the entire system from the rear to the front.
So now.... the abs light goes out and stays out ..
The Problem now the brakes, all of them! are not releasing "locked up"
The only way to get them to release is to bleed the pressure off. Only to have it happen once the brakes are applied again !
Are there some check valves in the abs that could fail? I would think not ....
Key points
abs light
soft pedal
high idle
Weez1
Jun 21, 2013 09:41 AM
