94 accord ex with abs brake issues
Old Aug 12, 2009 | 11:36 AM
deeprecon1's Avatar
Default 94 accord ex with abs brake issues
Ok ..so first off, It started with a abs light and a soft pedal and high idle.
Key points
abs light
soft pedal
high idle
So started cheap... master cylinder "brake", then discovered the booster was loosing vacuum. SO I replace it .... a bit of a pain but I got it done.
I then proceeded to bleed the entire system from the rear to the front.
So now.... the abs light goes out and stays out ..
The Problem now the brakes, all of them! are not releasing "locked up"
The only way to get them to release is to bleed the pressure off. Only to have it happen once the brakes are applied again !
Are there some check valves in the abs that could fail? I would think not ....
Old Aug 21, 2009 | 06:48 AM
welcome to the forum. Did you bleed the modulator
rstaggs01
Dec 12, 2011 09:14 AM
Thelandlordsmm
Aug 5, 2009 09:27 AM
proff
Feb 12, 2007 01:00 AM
DadDog83
Nov 26, 2006 09:53 PM
