B20 civic won’t rev past 4K RPM
Old Aug 8, 2021 | 11:47 PM
Ottwetre's Avatar
Default B20 civic won’t rev past 4K RPM
high comp b20 from HMO in my 98 civic won’t rev past 4K, it’s just cuts at 4K even with my foot all the way down on the gas.
im not throwing any codes.
im using an auto obd1 p75.
I have a rywire harness.
I’ve redone timing.
it drives fine under 4K and idles fine.
at first it wouldn’t rev past 3k, then I installed the rywire harness hoping that would solve the problem but now I can’t rev past 4k.
and it’s only while I’m driving. It’ll rev past 4k when stopped (if that matters)
Old Aug 9, 2021 | 07:25 AM
I know nothing about this stuff. And hopefully someone else who does know will come along and help.
Just wondering if this is a Vtec engine?
Because it goes above 4k easy in with no load
But with load it won't.
Could the VTEC be a cause??
Old Aug 9, 2021 | 08:04 AM
Ottwetre's Avatar
no it’s a non-VTEC engine and a non-VTEC ecu
Old Aug 10, 2021 | 10:48 PM
welcome to the forum. just wondering if you did change the ecu from the stock engine to the b20 ecu the donor engine.?
Dillonjones94
Feb 12, 2020 02:18 AM
Devin Grose
Oct 1, 2018 12:27 AM
kentucky
Sep 10, 2009 08:42 AM
knothagr8
Sep 6, 2009 02:48 AM
