Finding the downstream O2 sensor on a B18 Harness
Old Aug 24, 2021 | 10:29 AM
tjoudrey's Avatar
Default Finding the downstream O2 sensor on a B18 Harness
I've recently purchased a 1997 Civic SI coupe with a B18 swap that was thoroughly abused by its previous owner. Currently I am trying to find the connector for the downstream O2 sensor on the harness. Would anyone be able to point me in the right direction as to how to track it down? Ive looked under the car where one would expect it but no luck.
Old Aug 24, 2021 | 06:31 PM
welcome to the forum the normal downstream o2 sensor connector is located under the a/c condensor can.up front right. hooked up just after the Cat. how did the previous owner get smog done, does the b18 have headers, what year is the engine, does it have a cat. you have limited info, difficult to answer your request. sorry
Old Aug 25, 2021 | 08:43 AM
tjoudrey's Avatar
I posted a reply with some photos and details. It is awaiting moderator approval
Old Aug 25, 2021 | 12:00 PM
tjoudrey's Avatar
Since it appears that it is taking a while to approve my images I have found 2 4 pin connectors on the drivers side in front of the motor alike the upstream connector with
  • brown
  • brown
  • black
  • brown/black
  • white
  • red
  • blue/red
  • blue/white
wires respectively
Old Aug 25, 2021 | 02:52 PM
O2 sensors usually have four wires
One pair is for the heater circuit
Another pair is for the O2 sensor signal
Usually, two white or two black wires for the heater circuit
And any combination for the O2 sensor signal
I just do not know
Old Aug 25, 2021 | 03:13 PM
tjoudrey's Avatar
I think I may have found it. There is a 4 pin connector under the center console with 2 black and white wires, a red and white and a green and white.
Old Aug 25, 2021 | 06:16 PM
Does any of the connectors look like it will fit the O2 sensor?
Hopefully it is the right one?
Good luck
cinikal
Jan 16, 2021 11:01 PM
Raptor94
Jan 4, 2014 08:54 PM
Hondaegcivic
Sep 30, 2013 02:52 AM
ajaybali
Mar 29, 2010 11:31 AM
PRELUDEMAN09
Jan 30, 2009 01:01 AM
