Clothing hook in rear compartment
Old Feb 24, 2018 | 01:29 PM
Bxander's Avatar
Default Clothing hook in rear compartment 2018 CRV
can anyone help me with how to remove the clothing hanger in the rear of the car? I’m trying to install a trailer wiring harness, but when I attempt to pull out the plastic panel, I am unable to move it far enough out due to the hook.
Thank you for your help!
Old Feb 24, 2018 | 04:50 PM
Does that hook lever out like a door handle? If so look to see if the small panel can be prayed out,there maybe a release under it.
Old Feb 27, 2018 | 02:11 PM
Bxander's Avatar
When I flip the hook up, you can see this white plastic piece inside. There are no screws and the housing for the hook is all one molded piece.
Old Feb 28, 2018 | 06:11 AM
Try popping off the trim around the hook with a thin blade screw driver" gently". See what it covers ,it may be hiding a release.
aborgman
Feb 28, 2018 08:18 AM
ivory88
Nov 18, 2015 07:11 AM
anon125
Oct 4, 2014 12:39 PM
crazyaccord
May 15, 2007 06:07 PM
bchambers05
Jan 6, 2007 06:25 PM
