clutch or c/v axle
Old Aug 8, 2010 | 09:47 PM
jason allin's Avatar
Red face clutch or c/v axle
Hello, First time user to this forum.
I have a 86 Accord that ran great. 120k miles and just changed upper lower ball joints steering pump and rack. Now when I make u-turns the c/v joints click loud (with small leak from c/v were it meets the trans.) and also the clutch may be slipping? When i am in 1st the car vibrates when taking off and the RPM's in 4th and 5th go real high and the speed stays about the same? The shifting between gears seems good though?
Help. Jason
Old Aug 19, 2010 | 09:06 PM
tnutz's Avatar
older car probably cable clutch have someone check the tention on that other wise there are shims were the c/v meets the hub assembly sounds like things are binding one way and way to sloppy the other some thing wasn't done right i would go back to the guy who did it and tell him to finish the job obviously he half assed it every mechanic has his/her own morrels
Old Aug 20, 2010 | 07:19 PM
Default Thanks
Hey; thanks for the reply and advice. I have been waiting to here from someone. Take care..
jason allin
Aug 10, 2010 05:21 PM
bdmlilburn
Mar 26, 2009 04:22 AM
wheelieboy20
Aug 6, 2008 11:11 PM
jjipson
Nov 16, 2007 10:53 AM
mowntnbkr
May 31, 2007 07:14 AM
