honda clutch prob....97 dx
Old Jul 22, 2009 | 12:43 AM
knuckles's Avatar
Default honda clutch prob....97 dx
clutch seems to be slowly dying,,,,
i have to hold the pedal to the floor to shift gears and even then i can feel and hear it catch...
i bled the slave but i got worse it seems
should i replace the slave and cross my fingers or drop the tranny and replace the plates....?
(i had no help bleeding the slave so i opened it, pumped the clutch, put a piece of wood to hold it down, and tightened the bleed-valve back up)
Old Jul 22, 2009 | 05:08 AM
welcome to the forum, I'd bleed the clutch slave with 2 people first, dropping the trans is a big job.
Old Jul 30, 2009 | 03:55 PM
knuckles's Avatar
I bled the slave with friend, did not work,so i replaced the slave b/c it was only 20bucks, that didnt work......is the next step replacing the plates..?
Old Jul 30, 2009 | 09:13 PM
91haydenSI's Avatar
unfortunately yes. when you replace it though just get the whole clutch assembly they usually go for about 140 and napa or advance auto parts.. you could escape with new pressure plate but if the clutch is going out then that means the teeth are wearing down or getting grooved. just go ahead and fork out the extra cash and get it all done right in one shot trust me you will be happy you did it all now and in the long run it will save you time and money
wisener
Jun 18, 2009 04:14 PM
frenoloco
Feb 25, 2009 10:39 PM
civic2017
Sep 21, 2008 12:18 PM
civic2017
Aug 14, 2008 09:01 PM
unclecracker
Dec 9, 2007 06:17 PM
