The key is stuck in the ignition
Old Oct 5, 2019 | 08:12 PM
Mrich94501's Avatar
Default The key is stuck in the ignition
Has anyone else had a problem with a key stuck in the ignition? If so, how did you fix it? Any help appreciated. Thanks.
Mike
Old Oct 5, 2019 | 09:10 PM
Depends on how it is stuck in the ignition
If it is the gear selector not engaged in park then gear selector must be looked at
If it is the ignition cylinder then the cylinder needs to be replaced
If it is the steering wheel is turned to one side and has locked the key in position then move wheel to release
Old Oct 6, 2019 | 08:01 AM
Welcome in,most likely the steering wheel has locked it in,its happened to my wife three times as well as myself ,turn the wheel hard left while pulling the key it should release. Good luck.
sethalross
Dec 7, 2018 03:11 PM
hondadrivendaily
Dec 29, 2014 05:26 PM
Bob2000
Nov 17, 2014 07:47 PM
Illazell
Aug 25, 2010 10:05 PM
xlordt
Jun 7, 2010 09:11 PM
