08 honda bf50a electric trouble
Old 10-20-2019, 08:20 AM
bigbird74's Avatar
Default 08 honda bf50a electric trouble
08 bf50a BAZS3700682 cable assy. 32520-zw4-h11 ground wire burned up. What would cause the ground wire to wire.?. Trying to order a new wiring assy..
Old 10-21-2019, 03:02 PM
What would cause a wire to burn?
Too much current running through the wire
Or, resistance along the wire increases to causes heat to build up on the wire
Resistance can be in the form of rusty contact points or a little distance between contact points
The rusty contact points make for high resistance and the current that runs through makes it hot til it burns
The gap or little distance between contact points makes the electricity jump the gap
The spark causes heat to build up and then burn the wire
Too much current? If the fuse doesn't blow then it is probably a short somewhere after the fuse.
Old 10-21-2019, 03:20 PM
bigbird74's Avatar
Thanks for help
cappy6
01-09-2019 10:26 PM
Fordf250
10-22-2015 05:02 PM
yogibear27804
03-10-2014 09:17 AM
soccerman1144
08-23-2011 11:56 AM
pnomaster
09-13-2008 04:02 PM
Quick Reply: 08 honda bf50a electric trouble
