2010 Honda 4 stroke 90 fuel injection
Old Jan 30, 2023 | 01:09 PM
jaysbay's Avatar
Default 2010 Honda 4 stroke 90 fuel injection
First time posting, Just bought a boat with a low hour 90 H/P 4 stroke fuel injected motor. I took the motor to a Honda mechanic and got the bad news that the #4 piston has low compression. Had the boat out and the motor stalled ,after a bunch of times trying to start it i got it running but had a bad noise. Next day i dumped the crankcase oil and there was more water then oil.The mechanic advised me to buy a new motor, said it's not worth fixing. The motor has somewhere between 200 to 300 hours on it , I can't believe a 12,000 dollar motor is not worth fixing . I got a estimate for installing a new from honda top end and that was 7,500 dollars . It is crazy. If there are any garage mechanics out there that would be willing to pull the powerhead , machine the head & block and install a new piston & rod or all 4 please chime in. People tell me that motors in this condition are just throw aways , I just can't accept that . I am So Cal.
Johnny
(858) 688-2621
Old Jan 30, 2023 | 03:56 PM
You likely have more issues that just the piston. You may have grenaded the engine.
Old Jan 30, 2023 | 04:25 PM
jaysbay's Avatar
It is possible until you open it up, It still runs but certainly has low compression in the number 4 cylinder , Could be a bent rod,broken rings or even crank bearing on the crank. Who knows . It's just a shame that they are throw away motors. If i had the time I would tear it down myself and see what needs fixing and price out the parts . owell thanks for the reply
Johnny
Old Jan 30, 2023 | 06:07 PM
Parts could be a time factor.
83civic
Jul 8, 2022 05:42 PM
BrianMcNutt
Apr 10, 2022 09:19 AM
Sam Haltom
Sep 10, 2018 10:41 AM
gto93618
Jul 23, 2010 04:06 PM
gto93618
Jul 23, 2010 04:03 PM
