9.9HP dies while back trolling
Old Apr 12, 2020 | 01:14 PM
k2berta's Avatar
Question 9.9HP dies while back trolling
Hoping someone can help. At the end of last season, my 9.9 hp started dying while back trolling. Pretty much back troll at idle. When it dies it like it is just shut off. Will usually start with just one pull and idle for a few minutes up to 15-20 then die again. I don't have to pump the bulb or do anything so I'm not sure why it is dies. Runs fine at speed and does not die. Also turned idle up a bit with no change and tried fresh fuel.
Any ideas? Up to this point, this thing has been rock solid and even starts on first pull after sitting all winter.
Thanks.
Old Aug 17, 2021 | 02:12 AM
Cody's Avatar
Is it a two for four stroke? Does it run well with the hood off? I was having a similar issue on my four stroke and it turned out to be a bad exaust gasket. Exaust coming back up into the hood and choking out the carb.
Carson Logwood
Mar 2, 2017 03:52 AM
Mosbee
Feb 26, 2013 02:19 PM
Braxton
Jul 27, 2012 09:02 AM
lxfan97
Oct 28, 2010 07:59 PM
cravnspd
Nov 20, 2008 12:47 PM
