Honda Scooters Information on Honda's economical scooters.
Will not start
Old Apr 16, 2019 | 06:51 PM
Troy Barta's Avatar
Default Will not start
2009 Honda metro CHF50S. It was running but sat a while. I have replaced the carb, fuel pump and filter, ignition coil and spark plug, removed and cleaned fuel tank, new fuel. Has spark, about 135 compression, and fuel to the carb. Rear brake on and main kill switch off. Will turn over but not fire up, not even with starter fluid. Is there any safety kill switches I don't know about? Kickstand lock or seat lock have anything to do with it?
Thanks for any input
Troy
Old Oct 28, 2020 | 10:48 PM
Seapat's Avatar
Ever get it figured out?
Old Oct 31, 2020 | 06:50 AM
Unfortunately, he did not get any response.
So probably decided not to post the fix.
Old May 26, 2024 | 08:20 AM
Mikeee's Avatar
Default Honda Metro Not starting
You have a valve stuck and need to open up the motor.
Mike
Old May 30, 2024 | 10:57 AM
You have got gas and spark. Got compression. Then it must be timing or clogged exhaust??
Desire6162
Aug 27, 2017 07:28 PM
sureshsk
Sep 9, 2011 10:32 AM
STUART
Jul 29, 2009 03:31 AM
gixxerdude1979
Dec 17, 2007 08:52 AM
Relient J
Sep 2, 2006 05:43 PM
