B18/B16 Vtec head swap no start
Old Aug 4, 2023 | 11:14 PM
pnw_ek9's Avatar
Default B18/B16 Vtec head swap no start
So I bought a tuned ek9 civic with a b18b1 block, built b16 vtec head, gsr ls transmission, and tuned like a mf’er. It has antilag, launch control, and when you bounce off rev limiter it shoots flames. Pretty cool for someone who’s never had a honda before. So anyways the last couple days ago a guy pulled out in front of me and I did what any rational honda owner in my shoes would’ve done and banged off limiter to let him know I was there. It then proceeded to stall, so I tossed it in neutral and tried to start it again but nothing. Long story short, it has compression, and spark, not so sure about fuel but the fuel pump is priming. Thought it may have thrown the timing off but at TDC everything is just fine and the cams all line up along with the valves. Wondering if anybody could help me out/give me pointers to what it may be before I start throwing useless parts at it since it’s a freshly built motor.
Old Aug 5, 2023 | 06:44 AM
Will it start with alternative fuel. Ether.
Old Aug 5, 2023 | 01:24 PM
Since you tuned the ECU before, did you try to communicate with it now?
Does it show any DTCs.
Did you spray starter fluid into the intake to see if it starts??
Old Aug 8, 2023 | 05:07 PM
pnw_ek9's Avatar
I haven’t even tried any alternative fueling/starting method. Where would I even be able to find ether, I live in oregon btw, so not many alternative fuel choices.
Old Aug 8, 2023 | 05:08 PM
pnw_ek9's Avatar
I have a obd2 scanner but it fails to read any configuration of ecu so i’m thinking the person who tuned it used an obd1 ecu from a b16.
Old Aug 8, 2023 | 08:13 PM
Starting fluid is ether. You can use most any aerosol cleaner, ie. carb cleaner.
Old Aug 9, 2023 | 12:36 PM
pnw_ek9's Avatar
NEW INFO; I pulled the fuel rail off and found there is no rail pressure at all when attempting to start the car. Fuel pump still primed, but no rail pressure whatsoever.
I need help on wether y’all think it could be an electrical thing or a clogged fuel lines.
Old Aug 9, 2023 | 12:52 PM
With the line disconnected does fuel come out when priming?
Highly unlikely it's plugged.
Old Aug 14, 2023 | 12:23 PM
Brake clean is available in auto parts stores and can be used instead of starter fluid
What year is this vehicle and engine?
If fuel pump runs then there should be fuel pressure. Is there any fuel coming out?
May be the fuel regulator is faulty??
Maybe the fuel line was hooked up wrong? Maybe the return line is hooked up to the feed??
Don't know Just guessing
bryonmarise
Sep 23, 2012 06:42 PM
1997accordex
Oct 18, 2009 10:46 PM
arejay00si
Aug 21, 2009 05:13 PM
96civic
Dec 8, 2008 07:27 PM
Smurt Tits B16
Oct 14, 2007 03:43 PM
