Crank but no start
'97 CR-V
Recently replaced water pump with help from a friend mechanic. Now after making sure everything is TDC and put back together, got crank, spark, and fuel, but no start. After checking a few common things for no start, took off the valve cover and check the timing belt. My question is can a single tooth gap of lack between cam gears can cause my no start?
'97 CR-V
'97 CR-V
Check for fuel, spark, injector pulse, compression, etc??
