Crank but no start
Old 07-13-2023, 11:26 PM
Nordb711's Avatar
Default Crank but no start
'97 CR-V
Recently replaced water pump with help from a friend mechanic. Now after making sure everything is TDC and put back together, got crank, spark, and fuel, but no start. After checking a few common things for no start, took off the valve cover and check the timing belt. My question is can a single tooth gap of lack between cam gears can cause my no start?
Old 07-14-2023, 07:00 AM
Originally Posted by Nordb711
'97 CR-V
Record what it sounds like while cranking and post it so I can hear it.
Old 07-14-2023, 04:28 PM
'97 CR-V
So what has happened? Did you look into this more?
Check for fuel, spark, injector pulse, compression, etc??
Caddy daddy
05-13-2022 01:00 AM
Jamiecrv84
03-28-2022 01:52 AM
_gunner_
08-21-2015 08:31 PM
Dougie23
03-28-2015 06:58 AM
Honda96
11-13-2008 07:39 AM
Quick Reply: Crank but no start
