front brakes
Old May 16, 2011 | 05:10 PM
89crxhf/nasty\'s Avatar
Default front brakes
hi i am a new owner of an 89 crx hf and want to know if anyone can help me. when my brakes heat up they lock up. what should i do to fix this problem. thank you for the help and suggestions.
Old May 18, 2011 | 03:27 AM
welcome to the forum. Caliper may we dirty and need overhaul. Also fluid may need changing.
Old May 18, 2011 | 07:37 AM
Welcome to the forum,also You might want to replace the front rubber brake line.On the inside of the brake hose they disintegrate, which causes the fluid to go thru the line but not return when pedal is pressed. If it releases when car sits and cools off .then this is probably the culprit.Good luck,Bobby
Old May 18, 2011 | 09:51 AM
thank you for the help i will be working on it today hope all works out
87accordlx
Oct 10, 2009 02:48 AM
melissa777mo
Nov 4, 2007 04:57 PM
Dexter1
Jul 19, 2007 07:39 PM
04 mo neon
Aug 10, 2006 05:11 PM
paulseaside
Jun 29, 2006 11:23 PM
