New guy needs help 95 Accord wont start!
Old Dec 2, 2010 | 04:23 PM
agresiveone's Avatar
Default New guy needs help 95 Accord wont start!
I have a whole slew of problems with my 95 Accord. First things first i can not get it started. At first the vehicle would not turn over so i replaced the starter, Autozone gave me the wrong one. It started but the long grinding noise made me shut it off and look up the part number. I replaced it with the correct starter it now turns over but will not start.
It has good spark, cap, roter, plugs all fine. I do have leaking valve cover gasket and gromits the wells on top of the plugs are oiley so this may be the cause. but i cant imagine that it would not start with a little oil on top of 2 of the four plugs. I am replacing the cover seals and gromits.
I replaced the main relay.
All the fuses are fine.
I can hear the fuel pump kick on. I was told that i might need to check the fuel pressure? Im looking into how thats done.
Im at a loss other wise and not sure what else it could be. Any advice would be good. Good advice would be great.
Old Dec 2, 2010 | 06:46 PM
Note i did a fuel pressure check and i have plenty of pressure in line at the fuel rail.
Old Dec 3, 2010 | 02:43 AM
welcome to the forum. Check your timing, belt may have slipped a notch if you have not done a belt change for a while. Also are the spark plugs less than 100k. and wires in good condition.
Old Dec 3, 2010 | 07:17 AM
I agree,if you have fuel and spark,it must be the timing.
Old Dec 5, 2010 | 07:55 PM
My friend did the timing when he replaced the main output seal on the crank shaft no more then 40k miles ago. I am replacing the the plugs/wires while im in their. I plan also to do a full valve cover seal job including the lower gromits. But not looking forward to pulling the timing belt back off to get to the cam/rockers.
I figure thats why im getting oil on top of my plugs and wires.
I have a haines manual but having never done the timing my self im nervous. Any tips?
Old Dec 8, 2010 | 03:02 AM
try checking with u tube video's there may be some info there, also check with autozone.com free to register and may have your year accord for repair.
crshbandit
Jan 11, 2016 06:38 PM
alewis36
Jul 21, 2009 08:23 PM
petey882
May 6, 2009 06:08 AM
Jester419
Sep 26, 2008 07:41 PM
lorna
Feb 4, 2007 06:50 PM
