squeaky power windows
Old Jun 3, 2011 | 10:43 AM
PPOPHIL's Avatar
Default squeaky power windows
How do u fix squeaky power windows on a 2004 4DSD Accord EXL? I've tried WD 40 and the squeaks continue.
Old Jun 3, 2011 | 12:49 PM
did you check your actuator or lower attatch arm in the door?
Old Jun 3, 2011 | 05:47 PM
RiceCanRacing's Avatar
what you do is open the hood.. go into the area the motor is .. and cut the fan belt.. if that doesnt work than just drive it off a cliff...
just try PB blaster on the actuator arms otherwise good heavy grease works too...the motor also might make the squealing sometimes when it starts to go bad..
Old Jun 4, 2011 | 03:33 PM
Some times the felt strip wears out and needs replacing,when all the felt is missing the rubber makes contact with the glass,see if that may be the problem also.
jessetread
Aug 28, 2009 03:59 PM
derekcentrico
Aug 3, 2009 12:22 PM
micmoor
Jul 13, 2009 08:53 AM
broshot
May 14, 2009 04:10 PM
kantersp
Apr 19, 2009 07:12 PM
