2000 Odyssey CEL, misfiring fun
Old Mar 21, 2024 | 04:24 PM
tswitz1234's Avatar
Default 2000 Odyssey CEL, misfiring fun
I'm trying to keep running a 2000 Odyssey at 240K miles with a chronic CEL with p0301, 0302, , pending P1399 (basically all cylinders misfiring). It also had the EGR passage restriction, which I cleaned out and is now not flashing the EGR codes. I've replaced all spark plugs and coils and PCV valve. Car idles a little rough, runs smooth in the 1-2.5K RPM range, and then noticeably misfires above that, especially when you step on the gas (the CEL flashes, goes solid below that) I'm not sure what to do next (is is the PCM, cat, valves, O2 sensors, small leprechauns... or if its time to just junk the thing).
Old Mar 21, 2024 | 06:06 PM
Is it breathing OK?
Old Mar 21, 2024 | 07:46 PM
tswitz1234's Avatar
Is it breathing OK?
Yes, at least on the intake side although it does smell a little stinky.
Efre
Jun 23, 2020 07:31 AM
scj6771
Jan 11, 2014 03:46 PM
marley
Jan 12, 2013 10:22 AM
Paullec
Feb 10, 2010 04:30 AM
lwautomotive
Oct 8, 2009 06:54 AM
