2002 Ody making sounds when turning wheel
Old Nov 1, 2023 | 11:58 AM
1313ZZzz.1's Avatar
Default 2002 Ody making sounds when turning wheel
Sounds like my van is running a barber shop
https://www.facebook.com/johnwilson25/videos/839445554580428
That link is a very short video of the sounds my V6 2002 Honda Ody is making. Started 6 weeks ago but got worse yesterday. When I turn the wheel you'll hear get even loader. Is something loose? Is a belt rubbing on something? Maybe I should just drive straight. When I am driving it around it kind of feels like power steering when I make a turn but power steering fluid is full. Though, a mechanic told me last month I do have a power steering fluid leak and that my struts are nearly toast
Old Nov 1, 2023 | 02:16 PM
Sounds like the pump is going.
Old Nov 1, 2023 | 10:44 PM
1313ZZzz.1's Avatar
i found a youtube vid of the exact same noise and dude was specifically replacing the o-rings in a hose from the power steering pump pump..I will try to eliminate that as the issue next
Old Nov 2, 2023 | 07:38 AM
Do you hear the noise on one side only? Does it make noise on both left turn and right turn?
Possible wheel bearing noise??
Purple Frog
May 5, 2024 05:00 PM
C 10 man
Apr 28, 2022 10:26 AM
Dezso3
Jun 4, 2014 09:24 PM
nycredneck
Dec 30, 2013 07:50 AM
af279
Oct 31, 2010 06:51 PM
