2003 window regulator
Old 05-11-2009 | 03:49 PM
inewton55's Avatar
Default 2003 window regulator
I came home Sunday afternoonn to a partially down right front window. After taking it apart, the upper cable had pulled out of the window slide (which allowed the window to drop). After further dis-assembly of the regulator motor and cable reel, I found the cables pretty badly mangled on the spool. Does anobody know if this is a common problem and is there a recall or service bulletin on this? Or did somebody attempt a break-in by prying the window down and breaking the cable slide (and I mangled the cables by attemting to operate it)?
I am surprised that the whole regulator assembly is only $85 from the dealer. I was expecting more.
Thanks
Old 05-12-2009 | 11:47 AM
to the several sites checked, 03 ody had 2 recalls trans and fuel storage system (fuel tank) the window regulator/cable reel happens on many different types of hondas, not from trying to steal the car through the window, just a weak spot. i have read on many damaged reels and regulators/motors
stephshonda
08-11-2015 05:32 PM
saladfiend
03-11-2011 08:28 AM
dubele
03-25-2009 08:04 AM
theokengineer
11-25-2006 11:46 PM
jsachen
06-10-2006 02:39 PM
