High idle 3.5v6 2004
Old Jul 7, 2023 | 09:25 PM
NotYourAverageShadeTreeMechanic's Avatar
Default High idle 3.5v6 2004
The odyssey starts smooth, idles at 2400. I've checked position of throttle position sensor, I've replaced tps 3 times, I've changed entirely idle air control valve, replaced map sensor, pcv valve, intake gaskets, valve cover gaskets, and spark plugs. It still does it. It didn't start doing this until I fixed oil leaks and replaced intake and valve cover gaskets.
I've checked fuel trim they are between 5 and 0.
any ideas what to check next.
Old Jul 7, 2023 | 09:27 PM
Your intake gaskets is not installed correctly.
Old Jul 7, 2023 | 09:31 PM
Default Thank you
I will check it out first thing in am
Old Jul 12, 2023 | 07:31 PM
Default High idle fixed
Side gaskets on intake and throttle body gasket were so thin. I replaced with gaskets paper at advance auto. Fixed the issue.
Old Jul 12, 2023 | 08:40 PM
It must have been sucking a lot of air through there.
Dads_Honda
May 26, 2015 03:13 PM
Rynovdw
May 24, 2011 04:38 AM
ronzdad
Nov 18, 2010 12:57 PM
cody480gsr
Mar 12, 2009 12:27 PM
HondaMaren
Apr 15, 2007 09:43 AM
