Strange Heating Problem - '03
Old Oct 29, 2017 | 10:20 PM
clumsydropsy's Avatar
Default Strange Heating Problem - '03
I'm having a heating issue with my 2003 Odyssey where the heat coming from the vents, even with the temperature gauge on full heat, was luke warm. I did read some other posts that stated you should check the heater control value on the firewall. That value appears to be moving as the temperature gauge is moved. I then changed the thermostat. Now what is happening is the heat at idle or lower speeds is luke warm but gets hotter as the RPMs move higher. So, on the freeway, I feel a good amount of heat coming from the vents. On residential roads, the air is luke warm. Is it possible I got a bad thermostat? It doesn't seem like the heater core is bad. What else could be wrong?
Old Nov 13, 2017 | 01:41 PM
Abhorrent Sloth's Avatar
Thermostats are relatively cheap parts and can be bad, but that is unlikely. If a thermostat is bad then it will stay completely open or completely closed. If your vehicle is overheating then it is possible the thermostat is stuck closed. However, if your vehicle is not overheating, but your heat is luke-warm even when the vehicle is up to operating temperature, then it is possible you need a coolant and radiator flush. A radiator flush will insure proper flow and maximize the cooling/heat absorption properties of the coolant.
Old Nov 15, 2017 | 10:48 AM
Thank you for the reply. The problem ended up being the heater control value. I did flush the heater core thinking the main problem was there. I'm sure it didn't hurt because I did flush some junk out. I thought the heater core was the issue because the hose going in was hot and the hose coming out was cold. Apparently, I should of remove the heater control value and actually looked inside to see if the value was moving. The actuator on the outside was moving but that didn't mean the inside value was opening and closing. A mechanic told me if you bypass the heater control value with some heater hose and the heat works it's obvious what the problem is. Oh well. Live and learn.
n.h
Sep 21, 2017 08:40 AM
wavelover
Mar 8, 2017 04:40 AM
Slickeg93
Nov 7, 2013 10:33 PM
kaotic07
Sep 17, 2009 04:35 PM
fudwamper
Jan 17, 2008 11:02 PM
