What here is leaking oil?
Old Sep 28, 2019 | 09:34 PM
sclieu's Avatar
Default What here is leaking oil?
Hi,
2009 Honda Odyssey. I cleaned this area, and as soon as I turn on the engine, it starts leaking. Thought it was from the dipstick but seems to be from the electrical/sensor area, but I don't know what that is. I circled the area I think it's coming from, right next to oil dipstick.
Can someone take a look at the pictures and let me know if that is something oil can leak out of, and if so, what it's called so I can order replacement? Is there a gasket or some sort of o-ring there that has worn down?
Thx in advance:
Old Sep 28, 2019 | 11:58 PM
welcome to the forum. picture does not show entire switch assy. i would guess it to be a oil pressure switch assy. sku 37240-r72-ao1. go to cheaperhondaparts.com and enter your vehicle info and you can see if that is what you might be looking for.
Old Sep 29, 2019 | 12:02 AM
welcome to the forum it might be a oil pressure switch assy sku 37240-r72-a01. go to cheaperhondaparts,com and verify. you may only need the o ring or seal. 09 the ring may be old and cracked allowing the leak.
Old Sep 30, 2019 | 10:11 PM
sclieu's Avatar
Thx for the quick responses. I got the o-ring and installed it...we'll see. I'm a bit worried whether i have the correct o-ring. It did not fit flush but i think once it is screwed tight, it fills the housing... i did a quick check and it doesnt seem to be leaking but will need to keep an eye on it for a week or so.
Much appreciated!
Stevebow
Jan 10, 2023 10:54 AM
skunk_ape311
May 19, 2019 06:59 PM
kbrook1218
May 27, 2013 05:21 PM
elc0lomb1anito
Apr 3, 2010 11:40 AM
XHONDAX
Sep 17, 2006 09:31 PM
