2014 Pilot touring overheating
Old Jan 2, 2023 | 10:23 AM
arodriguez_pe@yahoo.com's Avatar
Default 2014 Pilot touring overheating
As I was driving my Pilot, I noticed the AC was not blowing cold air when it was idle for about 5 minutes and soon after I started driving, the hot water temperature light came on. I stopped the car and let it cool down and drove it home ( 2 miles) and left it alone. Any ideas what May be wrong with it? The car has 100K miles and I never replaced the thermostat or serpentine belt. I figured I start there first. Thank you all
Old Jan 2, 2023 | 12:42 PM
What kind of temps are you experiencing?
Old Jan 2, 2023 | 01:49 PM
I did not check the temperature it self but the water temperature came on and the needle was all the way up on H. Thanks
Old Jan 2, 2023 | 07:34 PM
welcome to the forum. do an easy check, from a cold start, let the engine idle, watch your temp guage, before the hot light goes on check to see if the fan goes on.( not the a/c fan.) if the fan does not go on it could be the motor. put 12 volts to the motor to see if the fan turns. if you do not have a temp guage, have another person sit in the cab to advise you if the hot temp light goes on to shut off the engine to cool.
Old Apr 18, 2023 | 05:22 PM
Tarvin890's Avatar
Default Obvious first
Check the serp belt..is it gon
fdxhawk8369
Aug 29, 2021 06:41 AM
DoubleDown778
Sep 19, 2020 09:49 AM
ChizzyHat
Jun 9, 2010 11:31 PM
Zajoden
Nov 25, 2008 03:10 PM
vdavenp802
Aug 26, 2008 03:51 AM
