Sport RC51, CBR, Super Hawk, 919, Interceptor, 599, Dream 50R, and NSR50R related information.
1977 XL125 2-Q's condensor-turn signal
Old Aug 11, 2023 | 12:59 PM
Beets442's Avatar
Default 1977 XL125 2-Q's condensor-turn signal
TIA --Have 2 Questions: 1).Condensor screw that holds it fell off,the condensor was dangling. believe it mounts to rear coil hole by top of frame?All the way thru with screw? Pic? Diagrams dont show direct mount.
2). Turn signals dont work, barely light up,wont flash. Relay works cause you can hear it clicking. When you use brake,the brake light flashes lightly when signal switch is engaged. Used ohm meter and checked wired for bad ground,like turn wire is ground to brake wire.clean all check out good. ???
Jeromehump123
Aug 12, 2022 07:24 PM
Shick Goan
Aug 17, 2020 07:10 AM
Kelsey
Jan 18, 2018 09:33 PM
mattjaja
Apr 24, 2013 07:58 PM
broguearcher
Mar 24, 2009 02:06 PM
