Utility ATVs Information about Honda's utility ATVs.
Clutz with a bad clutch
Old 05-01-2007, 01:16 PM
BIG MIKE's Avatar
Default Clutz with a bad clutch
Ihope someone can help me. I have a '99 Foreman 400 and no matter ifI adjust the clutch loose or tight or if the machine is cold or warmed up it won't release whenI shift.It was fine when new. When I put it in gear it jumps and if I hold the shifter up when shifting into 2nd it is still engaged and I can move. If I hold it down when shifting back into first,it will move.If I loosen up the adj. a turn and a half from the recommended setting it sometimes breaks loose with a bang. I just don't want to blow it up. It has 650 milesand about 150 hrs. I used it in very low speed (walking speed) pushing wheeled carts (approx. 150 lbs)for most of its miles and I wonder if I burned up the clutch and it's grabbing.The idle speed is normal and I changed the oil and filter 4 times and it is always clean and not smelly.I'm an old time gear head and mechanic, is there a manual available to guide me if I have to tear this thing down? I think I can figure out the nuts and bolts of the matter, it's just any clearances or torque values I might need to have. Thanks in advance.
Old 12-09-2007, 05:43 PM
Deleted User's Avatar
Banned
Default [Deleted]
[Deleted by Admins]
civichybridsue
10-04-2014 08:54 AM
EFS463
10-13-2012 07:18 PM
gkinsha
02-03-2007 05:29 PM
seekingbass
01-22-2007 11:05 PM
fondario
11-30-2006 05:51 PM
Quick Reply: Clutz with a bad clutch
