Crv wont start / no green key light
Old May 5, 2021 | 09:06 PM
  #11
If you are just looking for the green light then put aluminum foil around the key
that does not go into the ignition lock and try starting the engine.
This will prevent the immobilizer from reading the key.
See if this turns on the green immobilizer light??
Old May 6, 2021 | 11:28 AM
  #12
Carloscrv2003's Avatar
Originally Posted by Enrique Piedrasanta
I change the alternator. I have a brand new fuel pump, but I dont have spark or fuel from injectors and the green key light does not light up at all in the dashboard
I'm having the same problem here no spark no fuel no green key light no CEL crank but no start I already change the crankshaft position sensor and ignition switch dont know what to do
Old May 6, 2021 | 08:39 PM
  #13
Well, the first thing most people do is to check all the fuses
This can be done relatively quickly with a test light.
Black clip to ground. Preferably the battery negative post.
Each fuse has two test points. One above each blade or leg.
Touch probe to each test point.
If only one side lights up then fuse is blown
If both sides light up then fuse is good
If no lights then there is no power to the fuse.
Next thing is to plug in a scanner or code reader.
With the code reader plugged into the data link connector (DLC), try starting the engine
If it starts then you have a bad ground somewhere.
Read the diagnostic trouble code (DTC)
If there is a code then this will give you a place to begin you troubleshooting.
If there is no code then we must do some old fashion troubleshooting
Richie290
May 12, 2018 02:44 PM
cordovan66
Apr 12, 2015 07:38 AM
mohd3333
Dec 12, 2009 03:15 AM
honda114
Jul 4, 2009 07:30 PM
carewbeats
Jan 2, 2009 04:40 AM
