Dashboard Battery Light
Old Dec 26, 2018 | 02:30 PM
Mongo's Avatar
Question Dashboard Battery Light
Battery Light '03 CR-V Startup in the morning and battery light comes on. Only charging at 12 volts. Start driving and light goes off and charging at 14 volts. 2 days later same thing however at 50 mph light comes on only charging at 11.8 volts then light goes off and charging at 14 volts again. Whatever the problem is, it's progressing. Alternator? Serpentine? Sensor? Any ideas?
Old Dec 26, 2018 | 06:37 PM
Honda uses an ELD which senses the electrical load.
The ELD determines the state the alternator is in.
This helps to reduce the load the alternator puts on the engine
Which in turn helps saves gas.
My suspicions are that the ELD is not functioning correctly
Whether this is due to wiring issue or just a faulty sensor .. don't know.
welcome to the forum. it could be your electrical load detector, or the alternator.
Old Dec 28, 2018 | 05:22 PM
Lochinvar's Avatar
Does anyone know when Honda started using the ELD?
Old Dec 28, 2018 | 05:59 PM
Lockinvar, early 90's.
Old Jan 3, 2019 | 08:39 PM
Welcome in,take it to an Auto Zone or Advance auto parts place they can do a load test on the Alt.
akremer
Feb 24, 2019 06:27 PM
2003
Nov 2, 2018 03:58 PM
Mirob58
Jun 25, 2018 05:57 PM
Mmm123
Feb 8, 2017 04:14 AM
Kmontgomeryinc
Aug 17, 2015 05:45 PM
