Hard to find oil leak
Old May 10, 2021 | 06:53 PM
  #11
Jvincent's Avatar
Default Found it!
Oil leak came from the VTEC cover gasket located on the front of the valve cover and hidden behind the power steering pump and tensioner. It is just up and to the left of the items in my pictures. Good info from a locally owned Honda repair shop pointed me in the right direction. Had to remove the pump and tensioner to access it but easy from there. Hope this helps someone else with a similar problem.
Old May 10, 2021 | 11:35 PM
  #12
thank you for the feed back. will assist others looking for oil leaks.
Old Jun 19, 2023 | 09:02 AM
  #13
bennie's Avatar
when you say 'VTEC cover gasket" are you referring to the VTEC filter cover gasket?sorry i cannot find a VTEC cover gasket... i have the same problem as you had.
Old Jun 19, 2023 | 09:28 AM
  #14
Jvincent's Avatar
Default Pic
Yes, it is the VTEC filter cover located on the front upper left of the engine. Pic attached. I was surprised how much oil came from this leak. Good luck.
Old Jun 19, 2023 | 06:52 PM
  #15
bennie's Avatar
Thankyou very much Sir! recently i spent weeks messing around with the oil pressure switch at rear of block trying to stop a leak, cross threading and doing all sorts of other damage only to find it was the solenoid above this switch dripping onto it!!
Old Jun 20, 2023 | 06:55 AM
  #16
Jvincent's Avatar
Yes, this was a tough one for me mostly because I focused on the back side of the engine and it ended up being the “easier to get to” gasket on the front. Good luck with the repair.
Stevebow
Jan 10, 2023 10:54 AM
scoostraw
Jan 10, 2019 10:58 AM
kbrook1218
May 27, 2013 05:21 PM
clarkkentski
Aug 26, 2008 03:13 AM
XHONDAX
Sep 17, 2006 09:31 PM
