Oil Capacity Issue
Old Mar 14, 2018 | 06:18 PM
  #11
Waterboyz's Avatar
Originally Posted by bucwheat
I have done more research and on several sites the 17 CR-V 1.5 turbo holds 3.7. I would add 3.7 let it sit a while on a level pad and check your dip stick.
Please clarify:
3.7 Liters
or
3.7 quarts (US)
Old Apr 9, 2018 | 10:53 PM
  #12
Silverstar1's Avatar
Default Oil dilution
Check for oil dilution!
Old Apr 11, 2018 | 03:03 AM
  #13
Originally Posted by Waterboyz
Please clarify:
3.7 Liters
or
3.7 quarts (US)
quarts.
Old Apr 22, 2018 | 05:52 AM
  #14
Mingotoy's Avatar
The 2017-2018 CRV with the 1.5 liter turbo can develop an oil dilution problem. Gasoline is getting in the oil and making the level rise. My car is 2 months old and the oil level is now startin* to pass the highest dot. I will be going to the dealer this week. I have had 2 instances where I smell gas in the cabin after turning on the heat.
folks, check the internet and you will see several articles on this. Go to car complaints. Go to Facebook and type 2017-2017 Honda CRV and read the posts. I’m hoping that Honda can come up with a solution soon. This is a very dangerous problem that can lead to engine failure or worse. Can you imagine your engine blowing while driving on a highway with your children?
Old Apr 22, 2018 | 09:09 AM
  #15
Talking
<div style="text-align:left;">Thanks so much for the info Mingotoy.</div>
Old Dec 18, 2018 | 11:48 AM
  #16
Lochinvar's Avatar
Rule 1 when changing oil:
Forget numbers, and check with the dipstick.
Manuals can be (and usually are) wrong about something (because of typos, old information, etc.).
You will also usually find widely varying numbers on the web.
Your dipstick was engineered to be accurate, even though exact amounts of oil required can very between engines depending on exact construction, and wear.
So do as the Castrol guy says, and think with your dipstick!
sdking
Apr 9, 2021 03:29 PM
John000
Nov 11, 2019 10:21 PM
anon125
Oct 17, 2015 12:09 PM
mrcoolhead
Jan 31, 2013 07:38 PM
Khonsaiho
Jul 18, 2007 06:49 PM
