rear door latch won't open if too cold
Old Nov 18, 2019 | 05:34 PM
kayakterp's Avatar
Default rear door latch won't open if too cold
Hello I just joined this site and am wondering if anyone has a solution to the door opening mechanism (outside black button) not working if it's cold outside?
Our lease is almost up and I want to keep the car but only if I don't have to fight this door lock anytime it's cold outside. I have an SUV because I need to access the rear door often.
It seems this has been an ongoing problem that Honda has not dealt with?
Any thoughts would be welcome
Thank You
Old Nov 18, 2019 | 06:47 PM
Try using graphite to lube the mech. It wont freeze or gum up.
Old Dec 17, 2021 | 12:22 PM
beedubba's Avatar
This happens when the latch is broken. There's a technical bulletin about it:
https://static.nhtsa.gov/odi/tsbs/20...34376-9999.pdf
It's pretty easy to fix if you're handy. Just wait to remove the exterior lower tailgate trim until you have all the interior trim removed, so you can get at the back side of the fasteners to release them.
DavidM
Apr 2, 2013 09:13 AM
rm49
Jan 12, 2009 11:48 AM
bettystech
Oct 29, 2008 05:39 AM
nagem
Jun 29, 2008 03:06 AM
