is scheduled maintenance necessary
Old Jun 24, 2019 | 02:55 PM
areex81's Avatar
Default is scheduled maintenance necessary
Sorry if this question has been answered, but this forum is a little overwhelming. I have a 2015 CR-V with 12,960 miles and have owned iit since new, approximately 4 years. I had the car inspected at the dealer and he says I need the 3 year service which includes flushing the brake fluid, trans fluid, 4 wheel drive flush, injector cleaning (car starts and drives well) and alignment (Tires are not feathered and car tracks straight) . This would cost around $800-$900 plus parts. Do I really need all this done considering my low milage? I know the dealer usually cost more but this seems to be a lot of money. Is it something an independent mechanic can do?
Thanks
Old Jun 24, 2019 | 06:39 PM
welcome to the forum. since your car is out of Honda's 3 yr, 36k warranty which ever occurs first, you can do anything you want to to the cr-v. I am fortunate that I can work on my own Fit, Hr-v, Town and Country, 87 Bounder, but some work is to much for me to handle so I do have a independent Transmission shop that does all work I cannot handle. a shop that once the hood is closed, I do not have to worry or think about if the job was done right. so find an independent shop or mechanic that you trust to get the work done. enjoy the Cr-v, ive gotton over 200K+ miles on our previous Hondas. civics and accords.
Old Jun 24, 2019 | 06:40 PM
Your owners manual should have the schedule of maintenance.
These recommended maintenance items are necessary to keep your vehicle in good shape
However, the dealerships usually are trying to sell you something you don't need and try to scare you into paying for it
Yes, independent mechanics can do the same job but may not have the necessary fluids or parts.
Hyundai trannys are very touchy if not using their proper fluids. The power steering as well.
Do what makes sense to you. And what will keep your car under warranty
Old Jun 25, 2019 | 09:39 AM
areex81's Avatar
Thanks for your your replies, but I'm still wondering if I still need the 3 year service with only 12,900 plus miles.
Old Jun 25, 2019 | 06:00 PM
if you are not under warranty, you do not have to do anything to the car. no matter what the milage is.
Old Jun 26, 2019 | 10:41 AM
3illmesmart's Avatar
As others have said, you are out of warranty, so there is no obligation, but it is your piece of mind to deal with.
From your list:
Brake fluid - CAN take on moisture, that is why they suggest changing it, to prevent rusting from inside lines.
Trans fluid - you have CVT in your '15, but I don't think you are at the mileage yet.
4 wheel drive flush - see brake fluid. This will need to be done at some point, differential plates will slip, again, I don't think you are at the mileage yet.
Injectors - depends on your driving. If you putt around the city it can help, but if they just dump something in the tank, you can do it yourself.
Alignment - I wait for indication of problems, they charge the same whether they adjust or not.
All depend somewhat on your driving style and environment you live in.
Tango Charlie
Nov 25, 2019 10:35 PM
mlore
Feb 22, 2019 01:54 PM
OhioCivicOwner
Apr 20, 2017 01:40 PM
vbarlow
Apr 23, 2013 11:19 AM
