Starting Problem.......2015 CRV
Old Oct 20, 2018 | 06:06 PM
Marc's Avatar
Member
Default Starting Problem.......2015 CRV
When the ignition key in my wife's 2015 CRV is turned,the car will not start. And when the key is taken out and put in with the other side facing the driver, the car will start sometimes. But when the wheel is turned a little to the right while cranking, the car starts consistantly no matter what side of the key is facing the driver. And the parking brake is never on while cranking. What could be causing that?
Old Oct 20, 2018 | 11:27 PM
ignition switch if the key chain has a few extra keys, this will also cause the switch to fail. common fault.
Old Oct 21, 2018 | 07:50 AM
Marc's Avatar
Member
Thanks. I'll look into that.
Old Oct 21, 2018 | 10:05 AM
Can you watch the dash and see if the immobilizer light goes off while cranking??
Old Oct 21, 2018 | 10:38 AM
I second the ignition switch,they do wear out after a few hundred thousand starts. Also keys wear down and don't fully match the cylinder,
cordovan66
Apr 12, 2015 07:38 AM
honkymac
Aug 1, 2013 09:55 PM
darius25
Nov 20, 2012 06:52 PM
squirt31111
Oct 4, 2012 07:21 AM
derek123
Nov 26, 2006 07:31 PM
